labview 2013 crashing when restarting VI
My VI runs and I have no problems.
If I stop then Vi and re-run it, pretty much every second time it crashes.  It does not point to anything and the only message I get is:
Problem signature:
Problem Event Name: APPCRASH
Application Name: LabVIEW.exe
Application Version: 13.0.0.4051
Application Timestamp: 525595c6
Fault Module Name: NiViPxi.dll
Fault Module Version: 5.4.0.49152
Fault Module Timestamp: 51c243ad
Exception Code: c0000005
Exception Offset: 0000bbe0
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 6153
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
This only clue in the above I can find is NiViPxi.dll
I am using a PXI rack so maybe it is to do with one of the devices?
I would be nice to have more clues, does anyone know why labVIEW keeps crashing?
Rgds,
Sean
(3,054 Views)
Hi SeanJ,
I have a few questions regarding your issue:
- Does the crash only occur when you re run this particular VI that you are talking about?
- Is there any crash logs generated?
- What does your VI do?
- Would it be possible to show the code?
Jinfone
Applications Engineer
(3,018 Views)
Accepted by SeanJ
Hi jinfone.t
I managed to root cause it to a netway 72 PXI dll and have fixed the issue, (took a lot of effort!)
 Yes
 None that I know of apart from the output I pasted on the screen.  It's possible there is something in the event monitor
It function tests our product, (IOT)
I'm afraid not as it is proprietary.  However, the issue appears to be due to the dll.  Netway may release the VIs but I believe you are required to buy hardware/ software.
The issue I have is that LabVIEW is not handling this crash well at all.  It does not point to the problem dll nor does it drop a fail log that I know of.
Thanks for the feedback.
Ciao,
Sean
(3,013 Views)
