labview 2013 daq assistant missing
I can't see the DAQ assistant in Labview 2013!
Labview 2013 + real-time + fpga
Max 5.5.1
Visa 5.4.0
Device driver august 2013
Why?
Message 1 of 14
(15,135 Views)
You have not listed DAQmx. That is the driver that installs the daq assistant. I would suggest you click on the support tab to get the current version. I'm not sure the August driver included the one you need for 2013 since LabVIEW 2013 was released in August.
Message 2 of 14
(15,134 Views)
I have installed DaqMx 9.8
Message 3 of 14
(15,131 Views)
I have versio 9.8 for the DAQmx driver version
Message 4 of 14
(15,128 Views)
Accepted by RavensFan
Did you install that after you installed LabVIEW? If you didn't, then you should be able to get support by just doing a repair.
Message 5 of 14
(15,125 Views)
Did you install DAQmx AFTER installing LabVIEW?  Can you see any of the DAQmx palette?
Message 6 of 14
(15,122 Views)
I already had the 9.8 installed when I install Labview
Message 7 of 14
(15,118 Views)
And two of us have said that you must install the driver after. The driver cannot add support to a program that does not exist on your pc.
Message 8 of 14
(15,113 Views)
Just did the repair!  Will now reboot the pc to let you guys know!!
Message 9 of 14
(15,105 Views)
Still not available after a repair!!!
Message 10 of 14
(15,103 Views)
