labview 2013 daq assistant missing
All I can say is that the repair worked for me. When you did it, did you see the options for development installation and was LabVIEW 2013 listed? If the repair does not work, you may have to do a complete uninstall/install.
Message 11 of 14
(5,075 Views)
This is what i'm actually doing!  I uninstall and reboot!
Now when I started the installation I saw the labview 2013 available and check for installation!
Let's see if it works!
Message 12 of 14
(5,074 Views)
Ok,
now it works well!!
Thanks!
Message 13 of 14
(5,070 Views)
Then you should mark the message that most helped you as the solution to your problem, not your own thank you message.  First you will need to go to the options menu to the upper right of your last message to unmark it as the solution.
Message 14 of 14
(5,058 Views)
