labview 2014 install not finding drivers disk
I downloaded LabVkew 3014 and NIDevicesDrivers Aug13.  Labview installed fine on my Windows 7-64 bit system but it gives me an error that the drivers folder that I select does not contain the correct volume.  I tried the NI Device Drivers folder, the Aug13 folder, the Products folder, none were recognized as valid.
Anyone know the trick to get the Device Drivers loaded???
(5,525 Views)
Wow, you're a thousand years in the future?
The device drivers from August 2013 will not support LabVIEW 2014.  You need to find the drivers from August 2014.
(5,509 Views)
kNI needs to post them since this was the drivers disk for download on the website.
(5,503 Views)
Accepted by topic author jdervin@cox.net
(5,498 Views)
Thanks for the location!
(5,456 Views)
I have downloaded this and still get the same missing volume error.
(5,431 Views)
Hello Jdervin,
Here an article I found regarding to this issue you're experiencing:
"Why Do I Receive the Message, "The Specified Folder Does Not Contain the Correct Volume" When Installing National Instruments Products?"
http://digital.ni.com/public.nsf/allkb/291668D80E3FE2D1862572BB000D3C02?OpenDocument
Have you tried removing the curent installations and reinstalling after making sure that there's not any device drivers left installed? Same error?
Daniel C.
(5,402 Views)
