labview 6.0, rtdx com api, and ti dsp
According to the ti code composer studio tutorial (ti document spru301c.pdf
http://focus.ti.com/lit/ug/spru301c/spru301c.pdf, pg 1-13), one should be able
to communicate between labview and a dsp using the rtdx com api. I know that NI offers
the DSP Integration Kit, but it looks like some rtdx functionality can be accomplished
without this by using this com api. I haven't been able to find any examples of doing this. TI
did not seem to have any examples, I'm wondering if National Instruments has an example
or can suggest a method of doing this.
Thanks.
regards,
llp2
(3,247 Views)
I have some problems about RTDX. How can I using Labview tool kits for TI's DSP to do the RTDX communication between Labview and TI-DSP 6711 DSK. I never use TI's DSP tool kit. What should I do first?   thank you very much and i am looking forward to hearing from you.
(3,227 Views)
Daniel,
More information about the TI DSP Test and Integration toolkit can be found at this link
http://zone.ni.com/devzone/devzone.nsf/webcategories/257B18CF586F02BC86256CAA00755F10?opendocument&node=200188
Also you can find some examples for the 6711 DSK at this link.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=CCF2AC724ABB3000E034080020E74861&p_node=200188&p_source=external
One other tool you can use is the LabVIEW Debugging Workbench for RTDX Communication. You can read more about it in the first link above.
Ame G.
(3,189 Views)
Ame G.,
Thanks for your suggestions. i tried the TI DSP Test example(Audio_dsk6711_bios_ccs2.20), but the example could not work correctly.
The RTDX just transmitted the data from TI DSP C6711 DSK to Labview slowly. The data-rate is about 1 Hz. And i use the RTDX example in
TI DSP tutorial to try again. I got the same result. I just received the data( 8 integrals) from TI DSP C6711 in 1 Hz. I want to use Labview
to receive the data( 8 integral) in about 30 or 20 Hz. what is my problem? RTDX mode(continuous mode or non-continuous mode)? interrupt? or others?
i provide my problem. Thank you very much and I am looking forward to hearing from you.
regards,
Danial
2005/10/20
(3,165 Views)
Ame G.,
regards,
Danial
2005/10/20
(3,168 Views)
Daniel,
Please check this link for as it is related with your issue.
http://forums.ni.com/ni/board/message?board.id=170&message.id=144271&requireLogin=False
Ame G
(3,147 Views)
