labview 8.6, web publishing failed
Hi Cynitha,
Thank you for your infomation. Same with you, my setting is same.
But I want to ask, your VI which want to webcast, you put at what file? File at NI or other palce?
awkh38
Message 11 of 18
(1,972 Views)
Hi awkh38,
I put the file in other place.
cynitha
Message 12 of 18
(1,952 Views)
That means, when you want to select vi you want to webcast, you just use "browse"?
Then how about your computer connection?
Is it two pc connect together, or your computer connect to network by using modem router or router?
Thanks for your help.
Message 13 of 18
(1,949 Views)
I unbound LabVIEW in my laptop from the firewall, but I still can not see the broadcast LabVIEW programming via Internet.
Hi Cynitha,
Are you trying to publish your VI to the "Internet" so that it can be accessed by computers outside of your local network?  (example: by another computer in a different building/city/country)
If so, then how you connect to the Internet is important.  Most people connect through a router.  This means that you need to point your users to your router/modem's IP address.  Not your local PCs IP address.  To find the IP address of your router, you can use this page.  (Or log into your router and look at the Status page)   What is my IP?
You'll also need to enable Port Forwarding on your router and map Port you want to use to your local PC's IP address.  This way when a request is made to your router, it is forwarded to your PC.  You will need administrator access to your router to make these changes.
Patrick Allen: FunctionalityUnlimited.ca
Message 14 of 18
(1,942 Views)
Thanks for reply, Patrick.
I tried the basic function: to web publish and access the Web service on the same computer as the server: http://localhost/webservice/timer/2/5 but it failed again. I've checked my firewall. it allow labview 8.6 to go through.
http://my_IP_address/webservice/timer/2/5 did not work neither.
I've enabled IP forwarding on my router but I do not know how to map a Port to use to my PC's IP address.
I'm use Vista, could you please provide some suggestion on this situation?
Cynitha
Message 15 of 18
(1,873 Views)
Accepted by cynitha
Hi Cynitha,
Try install labview run time engine (of the same version of labview) in your remote laptop / desktop where you want to publish your labview host front panel and try to connect it. I was also facing the same problems that you guys are discussing and after doing this I got rid out of. Hope this will work.
MRK (CLAD)
Message 16 of 18
(1,857 Views)
Thanks for suggestion, MRK.
I tried run-time engine and it went well, too 🙂
Cynitha
Message 17 of 18
(1,848 Views)
Hi, please help me
I have a IP public for internet, when a publishin with labview, url is: http://mycomputername/aplication/example
but i really need for publicate in the internet a url: http://myippublic/aplication/example
can somebody help me please, how i can do it the change for publite in the internet...
good luck......
Message 18 of 18
(1,560 Views)
