labview 8.6, web publishing failed
Hi
I web published my programming using LabVIEW 8.6 by my laptop.
I can see it through a web brower in my laptop, but I can not connect to it using another desktop.
could any one help me to solve this problem?
cynitha
Message 1 of 18
(5,357 Views)
Cynitha,
If you can view the VI in your browser on your laptop then that means that you published the web page correctly and that the web server is running.
If you can't see it from another computer then you are having network issues. Your firewall on your laptop is probably rejecting the connection.
Nathan
Message 2 of 18
(5,353 Views)
Thanks for reply, Nathan.
is there any method to overcome firewall except turning it off?
cynitha
Message 3 of 18
(5,332 Views)
That depends on your individual firewall software. Firewalls always have some way of configuring exceptions.
Consult your firewall's documentation.
Nathan
Message 4 of 18
(5,302 Views)
Plz go to labview>>tools>>options>>web server configuration>>http port = 80
Sometime, port 80 will be occupied by other monitoring software.
Try to change to 81 or 82..etc
Message 5 of 18
(5,284 Views)
Hi cynitha
I also want web published my programming by using LabVIEW 8.0 in my destop.
But now is I can't publishing it, got error occur.
May I know how your setting at Web Sever: Configuration and Web Server: Browser Acess. I want to compare me and you one, see got wrong or not.
Andrew.
Message 6 of 18
(5,276 Views)
Hi awkh38,
In LabVIEW8.6, I go to tools > web publishing tool > select a VI that I want to webcast, then basically click some "next" and "finish".
for web server: configuration, I go to tools > options > web server: configuration > enable web server
for web server: browser access, the browser address is *, and I allow viewing nad controlling.
I think different versions of LabVIEW may have little difference in broadcast setting, I hope this piece of info helpful. 🙂
cynitha
Message 7 of 18
(5,264 Views)
Hi Fatty,
thanks for reply.
I tried to change the port to 81, but it didn't work neither.
could you give me some other suggestion?
thanks
cynitha
Message 8 of 18
(5,263 Views)
Hi NathanK,
thanks for reply.
I unbound LabVIEW in my laptop from the firewall, but I still can not see the broadcast LabVIEW programming via Internet.
could you give me some suggestion?
Cynitha
Message 9 of 18
(5,261 Views)
Plz goto labview>>help>>find examples>>browse>>Browse according to Task>>Industry Applications>>process control>>Tank simulation.vi
And
go to Tools>>web publishing tool>>VI name=Tank simulation.vi
Viewing mode>>
embedded
check>>request control when connection is established
next>>next>>save to disk>>connect
your IE will pop-up.
If no, then try another computer, try another lab computer, try your home computer. try very clean computer.
Message 10 of 18
(5,238 Views)
