labview 8 crashes with .NET runtime 2.0
i fixed the config problem. i am beginning to wonder if i have a bad install of .NET or more likely, a bad install of LV8.01 as there are some things that don't seem to be working right, such as typedefs. i have a typedef of an enum constant and LV changes the value i selected at design time to a different value at run time. Labview 8.01 can't be "uninstalled" can it? I'm thinking the only way to redo it is to rerun the update and the mass-compile again, or is this not the right way to do it?
Message 11 of 12
(1,054 Views)
No, you can't uninstall just the patch. You'd need to do an uninstall of LV 8, then install LV 8 and 8.01 again.
Message 12 of 12
(1,049 Views)
