labview application search .dll files,,,why??
Hello together
i am not an expert on labview
but i created a program (posted) then i bought the application builder an i created an application
on a other pc (with real time engine) i try to let run my application but always comes a pop-up who search a dll file...why? did i make a mistake with the application?
(2,951 Views)
Hi there
to be sure post the name of the DLL that's missing. But i guess you have to install DAQmx on the target system. Search the "updates and drivers" section on the NI page.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,922 Views)
Accepted by ago
a screenshot of the error message would be useful. However, I agree with Chris: as in your VI you are using DAQ Assistant, probably the error is caused by the absence of DAQmx driver on the target machine. So, either install DAQmx on this machine, or create an installer of your application adding also DAQmx as additional installer.
I hope this will solve your problem!
Bye!
Licia
(2,893 Views)
