labview build executable with dynamic vi's
There is nothing open!
I wil try to send you a part of the project, the whole thing is not allowed.
Message 11 of 13
(564 Views)
Poema,
Lets calm down for a moment.  I understand you are frustrated and under pressure.
A single png of what is wrong with your build specification cannot help us help you.  (That sucks doesn't it?)
What is in the "False Case"?  The "Library Dir" constant might need to be "App Dir".. Directory is your problem and we can help you fix that!  OK?
Message 12 of 13
(560 Views)
The 'false' case is used to run the program in development. FYI in development environment there is no problem and also when I use the external directory named 'Dynamic vis' the program runs ok.
Message 13 of 13
(544 Views)
