11-02-2008 04:38 AM
When running a Test Stand sequence, one of the tests calls up a labview VI that has had it's properties set to a dialog box and although it does pop up, sometimes it will appear behind the front Test Stand screen (if you minimise the Test Stand screen, you can see the Box). If I close all the National Instruments programs then re-run the Test Stand sequence the dialog box will appear in front of the Test Stand screen but this only seems to happen once.
Can anyone help with this problem???
thanks
Chris
Solved! Go to Solution.
11-02-2008 08:36 AM
11-03-2008 04:02 AM
Thanks, that works.
Chris
