labview driver for vitrek 4700
Hi all
i am trying to write driver for Vitrek 4700 HV DMM, this DMM communicate through RS232.
When i send commands from NI max test panel i get respond from DMM but, when i try to
communicate from labview  VI  i get visa read error -1073807339 to *idn queryfor same communication settings
my question is are any hidden setup in ni max test panel ?
Message 1 of 26
(4,969 Views)
Most likely you need to init visa with enabled end characters.
Hard to say without any code...
It might be that max and LV are opened at the same time.
Message 2 of 26
(4,961 Views)
Message 3 of 26
(4,953 Views)
@idans wrote:
here is my code
It is in fact (just) an image of your code... "ceci n’est pas une vi".
you might have better luck simply sending \n in the string. IIRC, visa uses the end characters for reading, but doesn't automatically attach the end character when sending data. Rational is probably that it doesn't know when you're message is complete. You could use multiple sends to send parts of one message.
I'd use "VISA Configure Serial Port.vi", as it's a bit less verbose...
Message 4 of 26
(4,947 Views)
I attached my vi after adding configure serial port and a /n char after *idn, but no good
Message 5 of 26
(4,941 Views)
There's no "/n" after "*IDN?" in that VI. And it should be "\n". And that will only work if the string is set to '\' code display mode. If not (normal display mode), simply add an enter.
Message 6 of 26
(4,936 Views)
my typo \n after idn?
Message 7 of 26
(4,933 Views)
You programmed the Serial port to use \r as an end character. Carriage Return (\r) should be Line Feed (\n). Probably, I didn't read the manual.
\r could be correct, but then you should also send \r. I think it should be \n though.
Message 8 of 26
(4,928 Views)
ok i got some advancment ' i added a for loop around *idn? query and i let run twice, at first iteration i get read error but in second loop i get a respons from instrument.
could someone explain me what is the problem? because i give the read vi long timeout ,5sec, but only at second attempt i get response
Message 9 of 26
(4,927 Views)
I'd remove the buffer flushing and changing the buffer size. This might be lagging (taking some time), spoiling the first send. I've never needed those.
A wait between the flushing\init and the send might fix the problem, but I'd avoid waits.
In general, I'd use the serial init VI.
Message 10 of 26
(4,917 Views)
