labview driver for vitrek 4700
Accepted by topic author idans
Ok i finally solved my problem with vitrek 4700 RS232 communication
attached is a zip fileof my labview driver for vitrek 4700 dmm
Message 21 of 26
(1,689 Views)
Message 22 of 26
(1,623 Views)
Your first kudo, for sharing.
Message 23 of 26
(1,617 Views)
Hi, thank you for your work put into creating this project. Unfortunately I am having trouble getting the software to work, it is trying to communicate with my vitrek, through an rs232-usb converter(I choose COM3 as visa resource). However, there are still errors and communication is not established. I am using LabView 2021 and I have also tried to connect via LAN but Labview does not see this device on the network at all (the vitrek is configured via DHCP).
Thank you for your reply
Message 24 of 26
(1,503 Views)
Yes, that is an error...
Does a tool like hyperterminal communitate?
As there might be a problem in your code, it might be useful if we could see it.
So how did you connect the device to your PC?
If you used a straight cable (no router or hub), there probably won't be a DHCP server for the device. The device probably has a display to show the address it's been given by the DHCP server.
I'd (always) give a device a static IP address. It simply is a lot easier to connect to than a dynamic address.
This address (static or from a DHCP server) needs to be in the same subnet as the PC. So if the PC is 192.168.0.10, give the device (for example) 192.168.0.42. (Also, talk to an admin to use another IP range, but that's another problem.)
LabVIEW won't 'see' the device unless you give it the right address. That's code, so again it would help to see it.
Message 25 of 26
(1,485 Views)
Thanks for this. I will try it out when our meter arrives.
Dumb question.... I was unable to open any of the VIs in the packed library version.
That's the first time that I've tried. I'm sure there is something simple...
Dumb question 2... Why is the packed library larger than the unpacked!
Message 26 of 26
(1,404 Views)
