labview drivers
Hello!
You will find in attachment the drivers for CCD 3000&3500. When I try to run the demo's, each labview demo tells me:
"LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS X, and / on Linux. Verify that the path is correct using the command prompt or file explorer."
If I have well understood, labview is trying to find the file "ccdload.ini", that I don't have and I don't know where I have to look for it(The problem is in the CCD load ini.vi).
I am sorry, but I am new of LabView...
Thank you very much!
Eleonora
Message 1 of 9
(4,892 Views)
It's looking for that file inside a folder called "ccd" that's in the same directory as the LabVIEW files. Where did you get the drivers from?
Message 2 of 9
(4,881 Views)
Hi Eleonora,
In the files you attached, in the CCD load ini.vi file I receive the same error information, but this is due to it detecting a non-existent GPIB interface.
Have you checked your GPIB interface? This tutorial on GPIB Controllers [link removed; article no longer available] may help you to understand what they are.
Hope this assists you!
Tori
Tori
Student
Message 3 of 9
(4,872 Views)
Hi!
I found the drivers here:
http://www.horiba.com/us/en/scientific/products/optical-spectroscopy/software/labview/thank-you/ (CCD-3000 & CCD-3500).
It gives me the same error!
Message 4 of 9
(4,855 Views)
Hi!
Yes I did. I used MAX (National Instruments Measurements and Automation Explorer). It recognize the CCD and it gives me an error (but I read in the forum that's neglegible) about *IDN query. The CCD is well connected (I think).
Thanks.
@Tori.M wrote:
Hi Eleonora,
Have you checked your GPIB interface? This tutorial on GPIB Controllers may help you to understand what they are.
Tori
Message 5 of 9
(4,854 Views)
Hi again,
Thanks for checking that.
What are you trying to achieve by running the demos?
The name "CCD load ini.vi" suggests that it is used to load an ini file.
If you hover over the vi icon using the context help you can observe the image below.
Tori
Student
Message 6 of 9
(4,838 Views)
Hi Tori!
I found the file.ini. This file comes with the SETUP disk of the detector. I am sorry to have thought about it only today!
Thank you very much for the help!
Eleonora
@Giallina wrote:
Hi!
Thanks.
@Tori.M wrote:
Hi Eleonora,
Tori
Message 7 of 9
(4,807 Views)
Glad you got it sorted Eleonora!
Any other problems let us know,
Tori
Tori
Student
Message 8 of 9
(4,805 Views)
hello, i am working in the same thing, try this, it worked for me.
please when you make the test tell me the results, i need to verify.
Message 9 of 9
(4,569 Views)
