labview eval download copy fault
I have download LABVIEW 7.0 Evaluation Software twice but the problem is
with
your file i.e when I try to Extract the File one of the files is not
getting
extracted.I used 2/3 Zip software but it didn't work The problem file is
LVCore12.zip which is around 9MB if somehow you are able to give the link
where
i can only download that file I can do it
(3,309 Views)
I'd recommend you try extracting LVcore12.CAB with winrar, take note of the corrupt files and we can just post those bits - then repack with winrar
(3,309 Views)
But the Original File lv70_eval.exe does not extract the LVcore12.CAB file from inside. So until LVcore12.CAB file is extracted from original download file i Cannot access it
The Error is "! C:\Temp\lv70_eval.exe: CRC failed in LV_70_EVAL\components\lvcore\LVCore12.cab. The file is corrupt ". I am using WinRAR for this operation and above error was thrown by WinRAR itself when i try to extract LVcore12.CAB from lv70_eval.exe file.
(3,309 Views)
I feared that may be the case... i will upload a copy of the cab to a webserver - (i'm assuming this wont be in breach of NI copyright) -, which will take about an hour. I won't post the address here so you will have to email me - sorensen@engineer.com and i will send you the link, assuming someone from NI doesn't advise me not to. So assuming the best and i hear from you I will leave the file available for a couple of hours..
Regards, Paul.S
(3,309 Views)
Paul... Thanks!
I'll check into the evaluation version to check and see if the original installer is corrput.
-Erik
(3,309 Views)
