labview foundvi archive exclusion
Given that LabVIEW automatically searches for sub VI in the following order:
By default, LabVIEW will look through the following locations in order (\* means LabVIEW will search through the subdirectories):
  • <topvi>\* - the location of the top level VI
  • <foundvi> - the location of the last VI found
  • <vilib>\* - the LabVIEW vi.lib
  • <userlib>\* - user.lib
  • <instrlib>\* - instr.lib
Question: How can a user exclude a subdirectory in one of these directories from the natural search?
For example: I want to exclude <topvi>\.git and <topvi>/.svn from the natural search.
How can a user set that exclusion?
I will be very grateful to anyone who can answer this question or provide any solution to this problem.
Best Regards,
John Whitcraft, CLD
(2,928 Views)
Hi Jandy,
Thanks for reaching out. I'm guessing you don't want to search through all your sub-directories, so that you don't have to do a lot of unnecessary searching. Could you just include the sub-directories that you do want to search through?
Keddy C.
Staff Software Engineer
(2,878 Views)
No. It’s the opposite.
I want to block labview from finding a VI in an archive area I designate. There  are old versions of vis in the archive, which if loaded would cause a failure.
Is there a way of masking out subdirectories from the natural search labview does?
(2,875 Views)
Like Mass-compile does with skipSVNFolders=true (discussed here)? I like a suggestion there, that hidden folders should be ignored, that way we don't have to care about if it is a svn or git-folder or anything else that should be ignored.
In the search directories there is e.g <topvi> and <foundvi>, which could be in a folder where there is a .svn-folder.
Certified LabVIEW Architect
(2,866 Views)
