labview help not working
HI everybody,
I am unable to open labview help
its showing some error
I am attaching the error & help screen shot
please help me to sort his problem
depending on selection of help error is changing
AB
Kudos are Accepted
Message 1 of 12
(10,134 Views)
Can you browse to C:\Program Files\National Instruments\LabVIEW 2010\help ?
Does that folder exist?
Is there a file called "lvanlsconcepts.chm"?
Can you open it (double click)?
Do you get a window that opens and a message that looks like the following?
LabVIEW Help
June 2010, 371365F-01
To comment on National Instruments documentation, refer to the National Instruments Web site.
© 2005–2010 National Instruments Corporation. All rights reserved.
If you type anything (ie: the letter "a") in the "Type in the keyword to find:" area (on the left), does it populate the window below it with all sorts of topics that start with the letters that you typed?
Message 2 of 12
(10,123 Views)
I can browse the folder & file
when i am trying to open the file
This is  the error.
AB
Kudos are Accepted
Message 3 of 12
(10,099 Views)
"If you type anything (ie: the letter "a") in the "Type in the keyword to find:" area (on the left), does it populate the window below it with all sorts of topics that start with the letters that you typed?"
It does populate but when i click one of the (intrested) items, help is unable to show full detals about the keyword. cursor behaves as if it is loading.
nothing shows up and remains still. Please help me.
Sansu
Message 4 of 12
(10,055 Views)
Hi Sansu,
Do all of the other features of LabVIEW appear to be working?
Have you tried closing then reopening LabVIEW to see whether the issue still reoccurs? And if you press Ctrl+h on your block diagram does the context help load?
Has the LabVIEW help previously worked? It could be an option to reinstall the software?
In the meantime you could try searching for things using the LabVIEW help online.
Hope the issue gets fixed soon!
Tori
Tori
Student
Message 5 of 12
(10,043 Views)
This software is recently installed and I guess it is first time that Im checking it.
I closed the entire Labview and reopened again, also I restated my PC.still it behaves in the same way.
Do i have to completely reinstall the software????
sansu
Message 6 of 12
(10,039 Views)
Hi Sansu,
As it's never worked before, there is a chance that you may have not installed the program fully i.e. including the documentation.
Rather than a reinstallation, you can just repair the installation.
Assuming you are running on a Windows operating system, go to the "Add/Remove Programmes" or "Programs & Features" menus. Select "National Instruments Software" from the list, before selecting which software to repair (i.e. LabVIEW) and click repair, then follow the instructions.
Hopefully this will add the help options that you appear to be missing!
Tori
Tori
Student
Message 7 of 12
(10,035 Views)
I have same problem with LabVIEW help. i have every thing OK to the file called "lvanlsconcepts.chm"? file is there. But when i double click on the file as u asked i have a partially opened LV help window and after 20-30 seconds i got the error message as follows . I have change my web browser to IE6 to IE7. I face the same error message when i open Help from LV and double click on any of the Index Tree.
Message 8 of 12
(9,980 Views)
Hi
This is generally due to the corrupt hhctrl.ocx file in your system 32 folder (assuming c:\windows\system32). Navigate to this folder and delete the file.
Download a fresh ocx file here
Then run this command regsvr32 c:\windows\system32\hhctrl.ocx in your command prompt.
This should solve the issue
Regards
Siva
Message 9 of 12
(9,955 Views)
i have done as you instructed but i didn't work for me. problem is still there.
Message 10 of 12
(9,928 Views)
