labview interface with arduino led dice
hi people i am doing a project of arduino LED dice.. I need to interface arduino with labview.. can anybody help me to create the vi in labview for the LED dice cause i totally had no idea how.. below are the attachment of my project.. thanks a lot
Message 1 of 14
(4,361 Views)
To interface this with LV you will need some sort of hw interface. The arduino boards have serial ports. You could use that or use some unconnected digital IO pins. n either case you will need to modify the dice code to interact with the interface.
What do you want LV to be able to do?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 14
(4,346 Views)
I want it to be able to generate random number for the LED dice.. I have programme to interface it but I just doesn't know how to built labview block diagram to interface with it..
Message 3 of 14
(4,339 Views)
So you want to generate a number between 1 and 6 in LV, send it to the arduine and have the arduino sw convert that number into signal that turn LEDs on to make the correct pattern. Is that correct?
I so you will need a digital IO interface for your PC. Do you have one?
You will also need to be able to write to that interface in LV. There are examples that will show you that.
Mike...
LabVIEW Champion
Message 4 of 14
(4,336 Views)
yes correct.. exactly.. yup i do have the digital IO..
Message 5 of 14
(4,332 Views)
Then you need to study up on the examples that show how to do digital IO. You will also need to modify the dice program to read the three bits.
Mike...
LabVIEW Champion
Message 6 of 14
(4,329 Views)
can you show me example how to build the block diagram for it in LV? cause i find through many sources i can't get any example how to build the block diagram for the LED dice to interface with arduino..
Message 7 of 14
(4,325 Views)
please help me to built the laview block diagram for it is possible.. sorry I really have no idea how.. total beginner.. thanks a lot..
Message 8 of 14
(4,314 Views)
Then you need to start by going through some of the tutorials.
Mike...
LabVIEW Champion
Message 9 of 14
(4,312 Views)
There is a toolkit from National Instruments for the Arduino, which can be downloaded for free I think  LabVIEW Interface for Arduino
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 10 of 14
(4,292 Views)
