labview multithread mutex
Hi all
   I have a project acquisition voltage by usb6211 with multi thread both run get error and single run is  Ok as my video,please help me check it ,How to fixed it,thanks
(4,270 Views)
Hi sageliuliu,
@Sam.Huang wrote:
Hi all
Don't try to read AI channels in different DAQmx tasks in parallel.
Your device only allows one DAQmx task for all AI channels…
Btw. your RAR archive is missing the LabVIEW project file (*.lvproj). You also should create standard ZIP files instead of using proprietary RAR formats…
(4,250 Views)
I can't watch your video because of your proprietary RAR file, but I assume you got error -50103.  If you had search for "error 50103"  (leave out the negative sign since that has a special meaning with google), you'll find this is a verify frequent issue with new LabVIEW programmers and found dozens if not hundreds of threads right away telling you the issue.
(4,243 Views)
Thanks for your comment.actually I want to set mutex control execution priority,when both start,run to same task,A run other standby A finish then B start,cross run no affect,please help me fixed it,thanks!
(4,206 Views)
I believe you can enclose it quotes like this "-50103" and you'll be fine.  i.e., error "-50103".
Bill
CLD
(Mid-Level minion.)
(4,198 Views)
Hi sageliuliu,
When you want to run part of your code after some other part has finished then you just need some wires to enforce DATAFLOW! No need for any "mutexes"…
Suggestion: It really helps when you would apply some better grammar/punctuation rules, like spaces after commas. The sentence you wrote would be much more readable…
(4,166 Views)
