Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
labview omronplc
labview omronplc
pop1
NI Employee (retired)
09-29-2007
09:44 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
各位好!
我在用labview 和omronPLC通信时,总是运行不通过.总是说VISA的初始化模块,有问题.我也把停止位按照常量输入,且将其定在20.我上传一下我的程序框图吧,看大家能否帮忙找找错,我感觉我的程序没有问题啊,都搞了几天了,太烦人了!谢谢大家!!!
ç´çº¿æ§å¶.zip 25 KB
0
Kudos
Message
1
of 3
(3,717 Views)
Reply
Re: labview omronplc
WangX
Member
09-29-2007
07:51 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi pop1
I suggest that you should translate your problem into english, especially in this area.
If you do so, everyone could help you then.
Best Regards.
0
Kudos
Message
2
of 3
(3,698 Views)
Reply
pop1
Author
10-01-2007
07:59 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
first ,thank you for regard my problem.the labview version I used is version 8.20 .I want to know which visaruntime version I should use?
I confront a lot of problem in my study.thanks a lot for your regards!
0
Kudos
Message
3
of 3
(3,677 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
