labview omronplc
各位好!
       我在用labview 和omronPLC通信时,总是运行不通过.总是说VISA的初始化模块,有问题.我也把停止位按照常量输入,且将其定在20.我上传一下我的程序框图吧,看大家能否帮忙找找错,我感觉我的程序没有问题啊,都搞了几天了,太烦人了!谢谢大家!!!
(3,742 Views)
Hi pop1
    I suggest that you should translate your problem into english, especially in this area.
If you do so, everyone could help you then. Smiley Happy
Best Regards.
(3,723 Views)
first ,thank you for regard my problem.the labview version I used is version 8.20  .I want to know which visaruntime version I should use?
I confront a lot of problem in my study.thanks a lot for your regards!
(3,702 Views)
