labview oop variant in private class data
i'm new to LabVIEW OOP.
Is there a way to get a variant control in the "Cluster of class private data" for a class? If not, is there an alternative for handeling variant data? I'm using LV 2013.
Thanks.
(3,417 Views)
Accepted by nollMarvin
You just use a variant control and put it in the big giant cluster.  It is the same for any other data type.  Is there a specific issue you are running into?
(3,397 Views)
Using the search function, i've found it!
(3,346 Views)
