labview,rfid microsoft access
I want to use Labview to read RFID cards from the 13Mhz RFID reader withCommunication interface TTL level/RS232 optional, extensible for RS485 interface.the tags read by the reader are suppossed to querry for their respective tables from the database of microsoft access and display the table's information. i am asking the experts to look at what I have done so far to see if I am going the right way because this is my first program to design that involves RFID, Labview and Microsoft access alltogether. what I have done so far is in the attachment.
(3,947 Views)
Hey MAKULA,
It seems that you forgot the attachment. I'll be happy to take a look at it once you post it. Are you running into any specific problems with your code? Have a great weekend!
John B.
Embedded Networks R&D
Certified LabVIEW Developer
(3,938 Views)
Let's keep it to this thread that he already started.
(3,935 Views)
Ah, thank you. I did not see the other thread.
John B.
(3,930 Views)
this is the attachement, please look into it and comment if I am going the right way, i am writing a labview code that will read the rfid tagd from the rfid reader and use the tag numbers to query for their tables in the microsoft access database.
(3,924 Views)
makalu,
Pay attention to the responses. You've started this thread when you already had one with the exact same question and bad code. Starting duplicate threads is irritating and rude. I made comments about your code in your original thread. You chose to ignore them and started this thread. Don't post questions if you don't read the responses. Do not continue with this thread at all.
(3,920 Views)
