labview sequence time function
Hello to everyone. I realize I'm asking a pretty easy question, but I've looked at all the examples. AND I am very confused. What I want to do is briefly this: I want to move a directional valve.
15 sec False-False (stop)
10 seconds True-False (up)
15 sec True-False ( down)
next; False-False should stay
Message 1 of 14
(4,161 Views)
You need a simple "State machine" with four main states: idle, wait, up, down
What's the difference between "True-False (up)" and "True-False ( down)". How do we know the difference?
Are there any timing precision requirements? Do you want to update and display elapsed time for each state? Should it be interruptible at any time?
Message 2 of 14
(4,116 Views)
Sir first of all thank you for your reply.
Are there any timing precision requirements?  - No sir
Do you want to update and display elapsed time for each state - Yes
-The program I am currently writing does exactly what I want. But I think there may be an easier way to do this.
Message 3 of 14
(4,099 Views)
Accepted by emre_
See if this can give you some ideas...
Message 4 of 14
(4,096 Views)
This is exactly what I was looking for, thank you. 🙂 🤗😎
Message 5 of 14
(4,090 Views)
Some glaring flaws:
  • Your loop spins as fast as the computer allows, millions of times per second, burning 100% of a CPU core. You need to set a reasonable loop rate using a wait function.
  • There is absolutely no reason to have the front panel maximized to the screen.
What's the purpose of the triangle button. That was not described. To be able to manually control the LEDs in the idle state, it would be easy to modify my code accordingly.
Message 6 of 14
(4,085 Views)
-you are right sir , I should add that.
I operate the valves in two different ways.
triangle mod --> up-down-up-down ( repeat)
normal mode--> up or down
Message 7 of 14
(4,082 Views)
But UP/DOWN is a control! So it does not cycle "up-down-up-down ..." under program control.
If you want to have a way to do up or down manually while the code is idle, I would do something as follows:
Message 8 of 14
(4,071 Views)
I understand better now. Thank you again for this. I edited a little.it was exactly what i needed.😊👍
Message 9 of 14
(4,063 Views)
hello sir, you replied yesterday.
I have been working on this issue for 2 days.
I need to add one last thing.
Is it possible to program a program that repeats this process n(5) times?
Message 10 of 14
(4,030 Views)
