labview vi slows down
I am doing extensive reading of the Ethernet socket and data processing. When I keep the mouse pushed over the panel it runs ok. As soon As I let it go it slows down to like one cycle per second. I have 4x2.4GHz Intel and 4GB RAM. Task manager does not show any ovewhelming CPU usage. Kepping the mouse button on the bottom taskbar application helps as well.
Why does it happen and how to fight it? thanks
Message 1 of 20
(4,731 Views)
can you post the vi so we can see what is happening?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 20
(4,727 Views)
I doubt it could help without the scanner I am reading from. Normally I should be able to read, process and display 20 frames/s. On its own it tends to slow down to a few f/s. Keeping the mouse over the Vi panel speed it up to normal. I was trying to play with the excution priorities but it only made it worse. I appreciate any ideas.
Message 3 of 20
(4,706 Views)
My first guess is that you are growing an array endlessly.  As it gets larger, LabVIEW needs to juggle memory to find an ever growing space to store it.  The other possibility is a string concatenation you have going on in the middle of the lower loop where you are concatenating more and more data to a string and storing it in a shift register.
Message 4 of 20
(4,688 Views)
Sounds like it might be a thread priority issue.  When the mouse is over the application, the application gets a boost in priority, making it faster.  Does this sound right?
Bill
CLD
(Mid-Level minion.)
Message 5 of 20
(4,676 Views)
I think I made the arrays fixed size. Initally I did not and it did not work.
The way it works is I get  a long string, need to throw out the header, then I store the values into arrays one by one. Based on certain criteria I throw some of them out so the array is almost never full, then I process the data in the array.
I ll check if the memory usage goes up. Could you be more specific as where the problem could be? I concate things more than once.  thanks
Message 6 of 20
(4,663 Views)
That is what i thought but still I have no idea how to approach it. Sometimes is just fine without doing anything, The trick with pushing the mouse button over the panel olways works.
Message 7 of 20
(4,661 Views)
I just checked the memory usage. For 10 min it stayed still the CPU about 6-7% load. Labview does not allocate any extra memory(it seems like). The whole system actually went dow from 915MB to 913MB RAM usage.
Message 8 of 20
(4,653 Views)
Have you tried running the profiler? This may help you to narrow down what is taking so much time. You might also want to spend a little time cleaning up the code. When I opened it it was difficult to follow what was happening. The diagram is extrememly large (much large than my 1600 x1200 monitor), the wires are flowing in all different directions and you have hidden code (code that is covered by other structures or hidden inside a structure that was resized to a smaller size). Organizing and cleaning up the code may help you to uncover the problem area.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 9 of 20
(4,647 Views)
I once used a Timed Loop (with the stop button wired to stop after the first iteration) to allow me to play with the code's processor affinity and priority.  Id be interested to see if that changes anything.
Message 10 of 20
(4,644 Views)
