labview
actually you just found a Known bug in LabVIEW
Branching wires to for loop inputs confusesses the compiler.  Use  an Always Copy
Search the forums or goto my profile page and look at the TAG "DidHeWriteTheCompiler"  Dr K. explains it in more detail than I can remeber offhand
(Drat---I'm getting old)
Message 11 of 13
(1,000 Views)
hi jeff
 My compiler give me just what i wanted in the output (an array of all the  number of successive elements less than 1 mm) of each thin patch. thats what i think i got ofcaurs i might be very wrong!!!!!
Message 12 of 13
(969 Views)
Hi jeff
i am working even harder you were right i have changed my code and this is what i got now.
would you be kind enough and tell me if i am making progress.
thanks
Message 13 of 13
(902 Views)
