Can somebody help me with the following problem?
I don't have a Data Aquisition board so I use my steppermotor controller, the MID-7604, and it's analog input to read from a
sensor (photointerrupter) which outputs 0 or +5 Volts. I want to count how many times an output of 5 Volts appears.
The problem is that the signal is not a Waveform, so the Daq functions in Labview won't work. I've tried to generate a waveform
from the signal but also no results.
What I have created now is a counter which counts every signal above an adjusted value. The problem is that it counts on and on
when the signal is above the value, I want it to count one time. (like a trigger which detect a low to high level signal)
In the attachment you see that program and an other I've found (event counter) doing what I want, but I haven't been able to transform it in to
my own problem. Please help me on this because I'm stuck right now.
Thanks in advance
Message Edited by Trabuca on 07-04-2005 02:56 AM
