led 64 phidget module error: 0x80080005, server execution failed
hello,
small question: I made a labview routine that works in combination with a phidget module (led64), but on another computer (several other computer, only installed the runtime of labview) the output does not work, (active x calls out fails, error:0x80080005, server execution failed)
hope someone can help me out,
regards,
brian
(4,179 Views)
Quick search with that error code leads to this thread. Post whether this solves your problem.
Mathan
(4,176 Views)
Hello Brian,
tank you so much for your post on our webforum. I found another possible cause of your problem, please have a look at this KB . Do you have the problem at only one PC or are more PC's involved?
If this doesn't solve the problem, and the same problem occurs on another PC, please post the LV version you are using, a link where I can find the phidget VI's  and an example to reproduce this problem.
Martijn S
NI Netherlands
(4,152 Views)
Dear ninlmartijn ,
thanks for your input, it gave us the insight to find the problem.
The runtime did not worked because it was build and compiled with a previous phidget driver, strange thing though is that is was the same version only another build.
problem solved!
thanks,
regards,
brian
(4,142 Views)
brian o wrote:
problem solved!
Can you please mark ninlmartijn post as solution to your problem? This will help others in the near future who are looking for same kind of problem and in need of a solution.
Mathan
(4,139 Views)
