leer señal de txt y filtrarla
Hola. Soy Sebastián de Argentina.
Tengo el siguiente problema:
Quiero filtrar una señal que esta en un txt. Cargo la señal del txt pero al ingresarla en el filtro el formato de los datos no es compatible.
Adjunto vi y txt
Saludos
Message 1 of 10
(4,586 Views)
Translation
I'm Sebastian from Argentina.
I have the following problem:
I want to filter a signal that is in a txt. Txt Cargo signal but to enter it in the filter the data format is not supported.
You can post here Spanish board
Message 2 of 10
(4,575 Views)
Have a look at this Knowledge Base
http://digital.ni.com/public.nsf/allkb/ABBD3A7BC25E17C8862561270058A4A0?OpenDocument
El enlace ofrece información sobre el error que se quiere obtener.
Message 3 of 10
(4,567 Views)
Hi, I know this. but the problem is tha the format of my data is not the correct; and i can't convert it to the right format to put it in to the filter. If If you can look my vi, maybie you can understend the problem.
Best Regards
Sebastian
Message 4 of 10
(4,555 Views)
This is another vi in were I’m tiring to do what you tall my, but I’ still having problems
Message 5 of 10
(4,553 Views)
Is this what you are trying to see?
¿Estás tratando de ver esta forma de onda?
Message Edited by Ray.R on 03-25-2010 12:49 PM
Message 6 of 10
(4,545 Views)
The entire 1228 data points correspond to one cycle of the signal
Message 7 of 10
(4,535 Views)
You do realize that your file was a 1D array and not a 2D array, right?
But that was not the problem. The problem was that fs was too low.
Have a look at the images below and the code snippet.
El problema estaba relacionado con FS con un valor que era demasiado bajo.
Tiene que ser fs / 2> = fh, donde FH = 400, por lo que fs tiene que ser> 200.
Message Edited by Ray.R on 03-26-2010 01:13 PM
Message 8 of 10
(4,520 Views)
Hi yesterday, I´ made this and its work. It`s to mach like yours.I use you design and works really good. Thanks for your fast and right response. I really appreciate and sorry for my bad English.
Thanks again
Best regardSebastian Lorandi
Message 9 of 10
(4,508 Views)
Glad that it worked for you.
RayR
Message 10 of 10
(4,497 Views)
