levenberg marquardt sub VI - LM abx vi
If you calculate the model using your X values and your initial parameter guesses, the last eight values are NaN.
Message 11 of 20
(1,728 Views)
Your model is not correctly parameterized, because a1 and a2 are 100% correlated. In the formula, they only show up as (a1/a2), meaning any change in a1 can be fully compensated by a change in a2.
Message 12 of 20
(1,720 Views)
right... okay, so this is because using those guesses would be an exponential plot shifted slightly to the left, and so it reaches y (or Rp) = 1 at a smaller angle, and above that it is infinity... so it would get NaN / inf answers if the guess is low... if you guess high, you still run into problems but not on every iteration.
i really appreciate your help, i have decided to pursue a different path (my orig code, calculating chi squared from some plots around the signal)... discontinuous functions are a pain. thanks again!
Message 13 of 20
(1,720 Views)
sorry, i didnt see your 121PM post when i put up my 125PM post.  what you said makes perfect sense and i see that.  however, what do you suggest i do in such a case?
Message 14 of 20
(1,709 Views)
Yes, the function is quite hairtrigger and a slight cahge in parameter can give NaNs. Maybe you want to skip the few highest points?
How accurate are the x-values? The Y-values.
Could there be systematic errors? For example if I allow slight shifts and offset, the fit can be quite good.
Message Edited by altenbach on 06-08-2010 12:03 PM
Message 15 of 20
(1,699 Views)
first of all, thanks again.  that plot looks great and i see how you "re-parameterized" the equation.
the problem i have with doing it that way is because the way i had it the values of the function correspond to the prism index and the material index, so i am able to get those actual values from the L-M.
i'm thinking that i can do something that sort of matches the fit you put up to the original equation, sort of using your equation as a conduit to take me to the right values. the x values correspond to 0.1 degrees, that will be very accurate with our ~$2k rotary stage (still waiting for it in the mail). the y values are based on a "noisy" signal which i generated with labview. i don't think the actual signal will be nearly that noisy but i am giving it a noisy signal in an effort to make it a good VI.
let me think about this a bit and i will get back to you with any updates.  thanks though, i can definitely make progress with your ideas.
Message 16 of 20
(1,687 Views)
 You are kidding, right?
If you fit for a1/a2 as two parameters, the values are 100% correlated and you don't get any meaningful result because the simulation outcome would be exactly the same if you would multiply the two parameters by a million, for example.
For example if the correct ratio is 0.5, the following results are equally good and levenberg marquard will randomly pick something:
a1=1, a2=2
a1=20000, a2=40000
a1=-0.003, a2=-0.005
etc.
There is no way you get actual values for both prism index and the material index!
Message 17 of 20
(1,681 Views)
i know what you're saying, and i share your disbelief.
but if you look at the paper attached, and my calculations, you will see what i mean. this is a problem i am trying to work around.
Message 18 of 20
(1,668 Views)
i think if i just use one parameter - the ratio of the index of the material to the index of the prism, which i called gamma - then i can make it work, because i will probably know the prism index to a very high degree.  there will be some uncertainty in that measurement but i think we will know it accurately enough.
Message 19 of 20
(1,648 Views)
Yes, typically you know one to determine the other. I would define the prism index as a constant, settable by the operator, then fit for the material index. 😉
Message 20 of 20
(1,631 Views)
