libdio96.dll
I am trying to load a vi I started on another computer. It keeps searching for several dll's on computer number two that are apparently on computer number one. Some of them are libmseries.dll, libmiteDma.dll, libsseries.dll, lib67xx.dll, libdio96.dll, libUSB-92xx.dll, libeseries.dll. There are more but it was taking too long to load. What am I missing on computer number 2?
gtb
Message 1 of 8
(5,340 Views)
Based on the file names I would guess a bunch of DAQ drivers... Is NI-DAQ installed?
Mike...
Message Edited by mikeporter on 06-29-2007 11:59 PM
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(5,337 Views)
I have NI-DAQmx installed.
Message 3 of 8
(5,309 Views)
What are the VIs that are looking for the dlls?
Mike...
LabVIEW Champion
Message 4 of 8
(5,305 Views)
Also, what drivers were you using on computer 1?  You will need the same ones on computer 2 as well as any libraries and VIs that you have written yourself.
Brian Coalson
Software Engineer
Message 5 of 8
(5,288 Views)
I believe it has something to do with DAQmx base. On the first computer I have all the hardware attached and working. Computer 2 does not have any of the hardware the program is controlling and does not have mx base.  I'm using the USB-9211x (whatever the correct pn is, it requires mx base)  thermocouple interface and it requires DAQmx base. When going to NI website to find mx base there are a dozen options of things to download but none of them seem correct so I have to check with computer 1 in the morning and see what I installed  for mx base. I also use DAQmx (without the base) for a different USB i/o device (6008), so both DAQ software is necessary.
If I search for "libsseries.dll" on computer2 I find "libsseries.dll.DAQMXB" so I'm not sure it is a problem with DAQmxbase except that MAX does not show  mxBase installed. Control panel shows DAQmx 8.5 installed and also no mxbase so I don't know what libsseries.dll.DAQMXB is.
gtb
Message 6 of 8
(5,276 Views)
I believe that the version of DAQmx base that you will need will be the version for Windows located here:
http://digital.ni.com/softlib.nsf/websearch/1C9142D75EFD398F862572970050C3C9?opendocument&node=132060_US
Brian Coalson
Software Engineer
Message 7 of 8
(5,260 Views)
Yes, that is the version I found on computer 1, fortunately with the already downloaded zip file. It did the job. Thanks to all for their response.
gtb
Message 8 of 8
(5,249 Views)
