library deployement error
I want to use shared variables (network or single process, doesn't matter), to make communicate two exe on the same PC.
All works fine with the development environnement. Things aren't so good when using exe.
I found this usefull link on NI site (in french)
http://digital.ni.com/public.nsf/allkb/67D0ED29F6FE8E6D86257538003436B2
but when I use the Deploy library method in the exe, I get an error 8 (you don't have the required authorisations)
Thanks for your help !
Phil
(3,426 Views)
Is the library set to read only? Is another application accesing the same file?
(3,397 Views)
Accepted by Ficare
it a problem with Vista's firewall...
(3,390 Views)
