library that defines the xnode is broken
I have an application running on a 9074 compact rio.  The application runs properly when I start it from the VI front panel.  However when I compile the VI and deploy it "Run as startup" it won't run.  When I connect to the application to debug it "Operate==> Connect to remote application" I see the "broken arrow" on the front panel.  There error list shows no errors, but if I check "show warnings" in the error list I see several block diagram errors, in the sub VI that connects to the FPGA application.  The errors are all "Open FPGA VI Reference: Library that defines the XNode is broken", "Invoke Method: Library that defines the XNode is broken" etc.
When I look up this error I get the helpful:  "This error occurs when the library that defines the XNode you used is broken. To correct this error, reconfigure the XNode."
How do I do that??
Message 1 of 13
(5,908 Views)
Hi PESobol,
I have searched Nis internal resources and have not found too much information on this error. Other people have found that reinstalls of LabVIEW (as well as modules and drivers) solved this issue. What version of LabVIEW are you currently using?
Scott B.
AE NI
Message 2 of 13
(5,867 Views)
I'm using 13.0.1 pro
Message 3 of 13
(5,865 Views)
Did doing a clean install fix your issue?
Scott B.
AE NI
Message 4 of 13
(5,845 Views)
No , same behavior.  I did a complete uninstall, reinstall and downloaded and installed the Xilinx additonal configuration tools.  Have the same problem.
Message 5 of 13
(5,828 Views)
I see that you have opened up a service request with the AE department. Instead of posting all of the troubleshooting steps both on here as well as through the service request I think the best option is to continue with the support through your service request. I will be working with the AE that was assigned your issue and we will work towards a solution. Sorry for the inconvenience.
Scott B.
AE NI
Message 6 of 13
(5,786 Views)
Hi I have exactly the same problem did you solve it?
Message 7 of 13
(3,984 Views)
Nope.  Now up to labview 2019 and still the same problems trying to compile applications to run on the CRIOs.   And zero response from NI  engineering.
Message 8 of 13
(3,978 Views)
6 years on and still the same problems, no response from NI engineering either.  Am I still supposed to keep quiet about it?
Message 9 of 13
(3,976 Views)
how did you deal with it? never turn off Crio ?
Message 10 of 13
(3,964 Views)
