library that defines the xnode is broken
Load and run the vi on the Rio from the project, then disconnect the project leaving the vi running.  If the Rio loses power you have to repeat
Message 11 of 13
(733 Views)
Is there any indication as to which XNode is broken?
Someone may have nested an XNode inside an XNode which can cause compile problems.
Can you post your source code?
Message 12 of 13
(728 Views)
My solution:  I have many LabVIEW machines at work and found one that was not broken.  All Xnode is, is just pre packaged error messages.  The error message is this.  Status=F
Code=43
Source=Your VI Name <APPEND>
<b>Complete call chain:<b>
   Your VI Name
Message 13 of 13
(42 Views)
