lighting system of five leds
hey, Im  facing a problem in lighting the five leds one after the other in a 0.5 sec delay. I have a true input to the loop containing the leds to let it work continueously,Can someone please help me find a way to fix this problem?
my file is attached here.
thanks
(2,401 Views)
Accepted by Abook7
You weve close.  her is a snippet showing corrected behavior for cluster 2.  You reall do'nt need to recreate the entire array for each itterarion.  I also moved the stop button to allow you to exit faster without waiting for the for loop to compleat all cycles.
Keep reading the help file!
(2,388 Views)
Kudos and Accepted as Solution are welcome!
(2,381 Views)
Why the OR function?  You are feeding in an array of 5 false values.  You OR that with something else, you are going to get the other wire.  ORing with a false array doesn't do anything.  (other than possibly limiting the array to 5 elements, but an array subset would do that for you.)
(2,379 Views)
