limited sampling rate on PCI-6052E
I am attempting to do a two channel measurement with a PC containing a NI PCI-6052E card which is capable of 333KS/s on LabView 8.2. With two channels each channel should be capable of 333KS/s / 2 = 166.5KS/s. Whenever I attempt to set the sampling rate above 94339 Hz I have the following warning and the vi doesn't work anymore.
Warning 200012 occurred at DAQmx Start Task.vi:1
Possible reason(s):
Clock rate specified exceeds the maximum conversion rate of the ADC. ADC overrun errors are likely.
If I setup a similar task in the Measument and Automation Explorer and I can easily do the two channel measuement at 160kHz with no errors. Above 166kHz I start getting the same warning (200012). The code I am using calls first DAQmx Create Channel.vi, then DAQmx Timing.vi, and finally DAQmx Start Task.vi. Everything else works fine and I have made measuements, but I can't increase the sampling rate above 94339 Hz even though it should be possible.
I've looked at everything and I can't figure out the issue here.
(3,786 Views)
I've the same problem, and i know the reason (i think...)
I have au PCIe-6323, with one ADC running at 250 kS/s. If i read 5 channels i will be limited at 250 kS/s for 5 channels, so only 50 kS/s/ch.
I suppose PCI-6052E is capable of 333KS/s for all channels...
Good day.
(3,755 Views)
The product page for your card does indeed say that it has a 250KS/s rate.
https://www.ni.com/en-us/shop/model/pcie-6323.html
My problem is slightly different. The card I use is capable of 333KS/s. So with two channels that should be 166KS/s for each channel.
The problem I have is that I cant go above 94KS/s so I'm limited far below what the card should be able to do.
(3,746 Views)
Accepted by voyn
Dear Voyn,
Thank you so much for your post on our webforum. If you create a task for one channel, can you achieve a higher sample rate? Are you able to reproduce the same problem with an example from the example finder? Please go to the browse tab end chose hardware in and output => DAQmx =>  Analog Measurements => voltage => Cont Acq&Graph Voltage-Int Clk.vi
You can select more channels as well. If this shows the same behaviour; which DAQmx driver are you using?
Martijn S
Applications Engineer
NI Netherlands
(3,734 Views)
Thanks, I used the code in the example to rewrite my own code and now it's working.
(3,716 Views)
