line indexing an output string
I have multiple test results coming out of a case structure.  The test result is text and is simply wired to a output string.  I would like to compile the results instead of the results over writing all previous results.
I've used an array to spreadsheet string to create a list for another application but the test result is not an array.
(3,005 Views)
Using shift registers, first initialize an array outside of the structure, then insert it into an array and have your new information wired as the new element, wire the output array to an indicator and to the shift register.
Hope this helps,
(2,999 Views)
If all your outputs are wired to the SAME output terminal of the case structure, you need to accumulate them in the loop you are using to execute your case statement multiple times.
You can either wire the results out of the loop and Auto-index or you can use a shift register to build the array one piece at a time.  The auto-index method has the array only available AFTER the loop is exited, whereas the shift register is available WHILE the loop is running.
Depends on where you need the data.
Shane.
Message Edited by shoneill on 03-21-2007 06:25 PM
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,987 Views)
I don't know what "compile" means in this context, bu you have many possibilities:
  1. If you only need the array at the end of the loop, use an autoindexing output tunnel.
  2. If you want to built the array iteractively, build it up in a shift register using "build array".
  3. If you just want to append a new line to a string, keep the string in a shift register and concatenate the result and a linefeed.
The attached shows simple drafts of all three possibilities. modify as needed. 🙂
Message Edited by altenbach on 03-21-2007 09:37 AM
(2,980 Views)
Thanks!  I am actually starting to see the usefulness of the different options...
(2,973 Views)
