linspace in labview
how to create linspace in labview?
Message 1 of 8
(7,024 Views)
Hi amandeepkaur,
Plain answer: type "linspace" into a text comment…
What exactly are you talking about? Are you talking about a MATLAB function of this name?
When you want something similar use the Ramp function in LabVIEW.
Or a FOR loop with some simple math to scale the loop iterator…
Message 2 of 8
(7,021 Views)
yes, if we want to implement linspace function of matlab in labview.
For example
w=[0:1:100]
Message 3 of 8
(7,001 Views)
Accepted by amandeepkaur
Hi amandeepkaur,
as I said before: use the Ramp function!
What have you tried so far and where did you fail?
What's your problem to read the help for the Ramp function?
Message 4 of 8
(6,983 Views)
For example
w=[0:1:100]
As Gerd already said, Ramp pattern will do what you want. (It even has additional options)
Of course if you want to write your own (i.e. implement) the function as a learning experience, feel free to try! All you probably needs is a FOR loop and a few simple calculations. If you get stuck, come back an ask for help.
Message 5 of 8
(6,959 Views)
thank you so much!!
I think it would be of great help.
i havent used anything yet.
I didnt get the answer in the first time. With diagram, it is more clear.
A very thank you again. I think it will be of great help.
Message 6 of 8
(6,937 Views)
thank you so much!!
It is not clear which post you are replying to. So is your problem solved or not?
Message 7 of 8
(6,911 Views)
yes, it is solved. both the solutions were of great help. i have accepted one as the answer
Message 8 of 8
(6,901 Views)
