list array
i have a 1D array.
the array is of 4 numbers.
i want to do the following,
i want to be able to wire the 1st number to an index, the 2nd number to an index and so on,
so basically i want to extract the 4 numbers and be able to use them individually, how can i do this?
- maryam.
(2,940 Views)
Index Array. The function is resizable to allow you to pick off additional indices.
It seems you're just starting out with LabVIEW.  To learn more about LabVIEW it is recommended that you go through the tutorial(s) and look over the material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
(2,938 Views)
