Place a comment on a tab or a cluster in labview 8.6
There is a very nasty bug on the labview version 8.6.
Unable to place a comment directly on a tab or cluster
The cursor does not put in place pointing
Should we wait for 8.6.1? Too bad for a product of such quality
As a beta tester, because of the limitation in time of the License, I have not been able to test at length version 8.6 and I had no back on the bug that I had met and submitted..
Thank you for a response from developers, support France did not yet replied… ..
AC
(2,743 Views)
Hi Kikujiro,
i see no problem with it. If it is not possible with a double click, then you can change the active tool. Change it to "insert text" function.
Mike
(2,727 Views)
Hi Mike,
Thank you for your prompt response.
With the "text" tool’s, if you put a comment on a tab control, the cursor is not at the point where you clicked. Warning: only 8.6 LV, it's ok on LV 8.5.x.
The problem is the same with a cluster command.
On the NI site, I see the same problem when I testing labviewonline.
The support France recognizes the problem but has not yet been returned.
Alain
AC
(2,718 Views)
