listbar control in front panel
Hello
I'd like to add a listbar in my VI.
The listbar is very similiar with the control menu in front panel. (see the figure)
Anyone know how to add the listbar (or similiar function)?
Thanks.
(3,047 Views)
There really isn't anything built-in with LabVIEW to do that, so you'd basically need to write it yourself. I'm assuming you're talking about some sort of floating window rather than a control on the front panel? If it's the latter you'd likely need to delve into XControls. Or are you asking in terms of an ActiveX or .NET control or something?
(3,032 Views)
Hello smercurio_fc
Thanks for reply. hmm....
Yes, I'm talking about a control on the front panel, it doesn't matter if it is floating or not.
Actually, visual C++ 2008 has that kind of example, but not in labview/
Is there some example for labview Xcontrol?
Thanks.
(3,015 Views)
Accepted by Mr.Fah
The reason why I asked whether it has to be a control or a separate window is that it will probably be easier to make it a separate window as this can be a VI. XControls are not easy to program. Yes, there are shipping examples of XControls. Just open the Example Finder (Help -> Find Examples) and search for XControl. There is also a tutorial on how to make them: Creating New Front Panel Objects with LabVIEW XControls.
Is the VC++ example something that was coded using standard controls? Where did you find the example? I'm curious to look at it.
(2,999 Views)
Hello
One of my friend said there is listbar control in VC++ 2008.
Sorry, I'm not sure.
Anyway, thank you so much
(2,980 Views)
I have Visual Studio 2010, and I don't see a ListBar control anywhere. I think he got that off the internet.
(2,960 Views)
