listing vi containing case
hello,
i encounter a 1502 error but my project is composed with hundreds of vis and to reduce time to inspect code
i would like to know is there is a way to list vi containing case structure
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(2,967 Views)
What does a 1502 error "LabVIEW:  Cannot save a bad VI without its block diagram." have to do with a case structure?
(2,965 Views)
hello,
because 1502 error could be caused by T/F constant wired to a case structure
Tinnitus
(2,963 Views)
Accepted by tinnitus
Ctrl-F for Find.
Search for objects and pick the case structure as the object you want to look for.
(2,959 Views)
Nice,
Regards
Tinnitus
(2,948 Views)
