lm3s8962 problem
I have lost the sound and display on my LM3S8962 Arm control.  How do I go about getting that back?
(3,095 Views)
Hey Jenmelton,
In the future, you would probably have more luck posting to the LabVIEW Embedded forums specifically.
https://forums.ni.com/t5/LabVIEW-Embedded/bd-p/420
For your question, can you be a bit more specific. When you say you have lost them do you mean that they are no longer working properly? Or, do you mean that you have physically lost the buzzer and display?
If you feel that it is a software problem and your code is not properly functioning please describe the architecture of your code.You can always test one of the shipping examples as well.
Was it properly working before and just recently stopped working? Or is this a new project you have started that was not working correctly?
Tim A.
(3,082 Views)
hi, friend if your screen is damage ARM could buy another but not recommended since in any case it is better to buy a new card, you can check the following link
https://www.sparkfun.com/products/9678
(3,047 Views)
