Howto: Embedded Systems?
I developed a data acquisition system with a custom hardware device for rehabilition.  I used LabVIEW to construct my software but I would like now to have an embedded system, rather than using my laptop.
I have done a little research on where to get started, for essentially making my system portable; rather than using a laptop to run the VI.
I have been looking at the LM3S8962 and the Raspberry Pi with Linux.  Preferrably, I would like something with a screen to essentially run the front panel of the VI.  Where do I get started and whats a feasible board to look at for an application like this?
Thank you,
Dan
(3,054 Views)
Also have a look at ni.com/embedded
Christian
(3,039 Views)
Hey, man I'm also working on it I recommend a book where you will find more information
http://books.google.com.pe/books?id=mb5d_xeINZEC&pg=PA337&lpg=PA337&dq=labview+arm+cortex+m3&source=...
(2,952 Views)
