load error "memory or data structure corrupt"
When I try to load my VI, I get the error "Memory or Data Structure Corrupt".
An error occured loading VI "Test.vi".
LabView load error code 23: There is not enough memory to load this VI.
It then spits out a log which points to errors in //labview/branches/Constellation/dev/source/panel/ZUtility.cpp
and //labview/branches/Constellation/dev/source/panel/loaddata.cpp
This sounds pretty severe (unfortunately, my backup is a while back). Is there anyway of recovering the old data from the (as it seems) corrupted file?
adrian
(4,761 Views)
hello there,
try this post:
Re: insane object BDHP +828B4 {graphics} (0x80):Front Panel Terminal (Term)
or post your vi. maybe someone with another version of LabVIEW or another OS can open it.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(4,758 Views)
OK, I'm attaching the VI in question. I've already tried launching it on another PC but maybe someone can manage to open it.
adrian
(4,755 Views)
