loading dynamic vi
hello ni,
             i made a simple data acquisition customized visualization, here i made a main vi under this i will load my control, graphs using templates. what happends here is.. when i load this template then i click on the main panel  the template vi's are get minimized. if i did separate vi panel then it was not get minimize...........
i want to load my dynamic vi template with in the main vi, and i can able to click on the main panel so, the dynamic vi should not get minimize...
can you suggest me .......
Balaji DP
(4,039 Views)
They are not getting minimized. They are going behind the main VI. I would suggest making the subVIs "floating" via the Window Appearance options.
Other comments:
  • You have no mechanism for stopping the spawned subVIs if you press the Exit button on the main VI.
  • The timeout on the main VI's event structure is unnecessary. Leave it unwired, and create a "Value Change" event for the Exit button.
  • Be careful about using the Current VI's Path function.
(4,012 Views)
Accepted by Balaji_DP
thank you,
                    then, when i open the each vi... it shows in taskbar.. i want to hide the template vi.... but it show the main vi...
how to do this?
Balaji DP
(3,986 Views)
I don't quite understand what you're asking. The template VI is not being shown. A new copy of the template is created and you get a new VI. What do you mean by hide? Do you mean hide its window? Also, I don't understand by "show the main VI". Show the main VI what?
Also, I don't understand why you marked your question as the solution.
(3,965 Views)
