loading fpga bit file in higher version
Hi is there a way to load a bit file generated through labview fpga 2011 in labview fpga 2012 ? or do I have to recompile the code for 2012?
(2,577 Views)
Hi sandee,
when you upgraded the calling host code you should also upgrade the FPGA code - by recompiling...
(2,571 Views)
