Is the Nexys2 board (with spartan 3e FPGA) compatible with the FPGA module
Hi my name is DIego and I was wondering if anybody here knows if the NEXYS 2 board (with spartan 3e FPGA) from DIGILENT is compatible
with the LABVIEW FPGA module.
Digilent is also the Manufacturer of the SPARTAN 3e STARTER BOARD
Message 1 of 24
(7,185 Views)
Diego:
The NEXYS 2 is not officially supported, but if you'd like to try it, you can attempt to follow the guide for the Spartan 3E here (substituting your NEXYS 2 for the Spartan 3E).
Again, the NEXYS 2 isn't officially supported, so if it doesn't work like the Spartan 3E starter kit board, then you won't be able to use LabVIEW FPGA with it.
Good luck!
Caleb Harris
National Instruments | http://www.ni.com/support
Message 2 of 24
(7,172 Views)
Hi Diego, Did you ever get the board working with Labview I was going to try the same thing and just wanted to see if I would be wasting my time?
Message 3 of 24
(6,974 Views)
Sorry dude but it´s imposible to get the nexys 2 working with LabView
Message 4 of 24
(6,965 Views)
Thanks for the reply. You have saved me a lot of time!
Message 5 of 24
(6,952 Views)
Can you share how you are using the Nexys2?  Is this for a senior design project?
Message 6 of 24
(6,943 Views)
I m using this board for a coursework project, I m triyng to run Linux on it
some one know if is this possible ???
Message 7 of 24
(6,916 Views)
I would recommend some of the IRC channels/mailing lists dealing with uCLinux (Google is your friend)
Otherwise, as good a place to start as any would be here (result of a quick search)
Message 8 of 24
(6,887 Views)
Frenky 已写:
Check this link:
http://ece-1.rose-hulman.edu/cadhelp/index.php?option=com_content&view=article&id=85:set-up-a-new-pr...
great! But how do I build the nexys2 support files?
Message 10 of 24
(6,738 Views)
