loading multiple vis in a subpanel
hi,
i have a vi that loads multiple subvis in a subpanel(the same subpanel) depending on users choice. it works fine but when i try to use it remotely and acces it from a web page, if i choose the same vi multiple times it works ok (the controls respond very slowly though) but when i try to choose another sub vi labview crashes with an acces violation error aka dr watson's log. for loading the subpanels i used the method provided by ni http://zone.ni.com/reference/en-XX/help/371361F-01/lvhowto/loading_panel_in_subpanel/ giving as an input parameter - depending on the choice made - the subvi's path. i sense there's more to that but i can't figure out what.
help please!
(2,686 Views)
Duplicate post: http://forums.ni.com/t5/LabVIEW/remote-subpanel-causes-error-c0000005/td-p/1555484
Please don't post the same questions multiple times.
Christian
(2,681 Views)
