loading multiple vis in a subpanel
hi,
i have a vi that loads multiple subvis in a subpanel(the same subpanel) depending on users choice. it works fine but when i try to use it remotely and acces it from a web page, if i choose the same vi multiple times it works ok (the controls respond very slowly though) but when i try to choose another sub vi labview crashes with an acces violation error aka dr watson's log. for loading the subpanels i used the method provided by ni https://www.ni.com/docs/en-US/bundle/labview/page/loading-a-front-panel-in-a-subpanel-control.html giving as an input parameter - depending on the choice made - the subvi's path. i sense there's more to that but i can't figure out what.
help please!
(3,151 Views)
Duplicate post: http://forums.ni.com/t5/LabVIEW/remote-subpanel-causes-error-c0000005/td-p/1555484
Please don't post the same questions multiple times.
Christian
(3,146 Views)
